Mine is in a wrappers shop as we speak - collecting tomorrow evening
SunTek Film in NJ
Hi IBad2,
I have had PPF applied to two Jaguars and the work was done by Lee Berbs located in Hillsborough NJ which is not too far from Princeton and where his shop is located. Lee is an outstanding installer and perfectionist who is authorized with Expel and SunTek films. These are the only films that he uses and in my case, he recommended going with SunTek since he felt that my metallic paint would come through better with this film over using Expel. Sun Tek was also a bit cheaper. He works primarily on high end cars and is not a detailer. The only work that he does is PPF film and I think that he also does window tints. I have no relationship to him other than being a satisfied customer and I highly recommend his work. You can search his name on Face Book which is where he posts many of his completed jobs for you to view. Hope this is helpful. Ed |
Thanks Ed
Originally Posted by spanky145
(Post 1509233)
Hi IBad2,
I have had PPF applied to two Jaguars and the work was done by Lee Berbs located in Hillsborough NJ which is not too far from Princeton and where his shop is located. Lee is an outstanding installer and perfectionist who is authorized with Expel and SunTek films. These are the only films that he uses and in my case, he recommended going with SunTek since he felt that my metallic paint would come through better with this film over using Expel. Sun Tek was also a bit cheaper. He works primarily on high end cars and is not a detailer. The only work that he does is PPF film and I think that he also does window tints. I have no relationship to him other than being a satisfied customer and I highly recommend his work. You can search his name on Face Book which is where he posts many of his completed jobs for you to view. Hope this is helpful. Ed Hi Ed, if I can't find a local ok installer I may use the guy you recommend. I'm located in Riverdale, which is far from the Princeton region. Plus, I might be wrong but I don't think the install job can be done while I wait , so I'd need to have someone follow me to the installed which isn't easy with people's busy schedule . I appreciate the info. |
1 Attachment(s)
Originally Posted by lsbrodsky
(Post 1507893)
Well as far as I am concerned my paint is great, every bit as good as my Porsche was. I decided to clay bar my car after I got it and it felt unnecessary, the paint was already clay bar smooth. I have not found any obvious imperfections in my washing and polishing.
Larry |
if it was tar - then you should use a tar remover/dissolver first and then clay bar it
Originally Posted by ioneabee
(Post 1509633)
