Removing Side Skirts
I just received the proper CF wrap that I ordered and really wanted to remove the side skirts to make wrapping them easier.
I got down and looked under the car for the first time, and low and behold... There are no bolts visible... Anyone know how the side skirts are attached and how they are removed? I assume there are a few bolts or screws and probably a few clips hidden down there somewhere. Thanks in advance for any info! |
Pretty sure they can be wrapped on the car without having to remove them...
Originally Posted by buickfunnycar.com
(Post 1247205)
https://cimg8.ibsrv.net/gimg/www.jag...199efd2759.jpg
I found a post where an owner stated: "I just replaced one. While the cost for the part is 400, it's not as simple as you'd think to add. The bolts are blocked by the paneling under the car, so you have to pull all that before you can replace the skirt" |
Mshedden (or mods), how about copying that previous post into the 'How To' sticky thread? Good stuff.
I was of the same mindset, remove and then wrap. After trying both ways, do not remove the side skirts to wrap! It is a real PITA to remove the skirts and it is very easy to wrap the side skirts with them on the car. Leave a little on the top edge for the tuck in and you get a very high quality look.
Helicopter tape! Helicopter tape!
(I couldn't control myself) (Oh, and what *is* helicopter tape?) |
Originally Posted by lizzardo
(Post 1247547)
Originally Posted by mshedden
(Post 1247624)
Its a 3M brand clear protective tape, similar to paint protection film material, but probably quite a bit thicker. You can see where Jag are using it - rock chip area.
(Post 1247301)
Originally Posted by F-typical
(Post 1260332)
Hmmm... Something to look at: can I adjust the position of the panel so that it better aligns with the doors...
| All times are GMT -5. The time now is 06:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
