review on porterfield r4-s brake pads
Received 3,114 Likes
No special method or tools needed, these are fairly old-fashioned brakes that can be bled the old fashioned way, so either gravity bleed or pump using the brake pedal or use a powered pump like most shops do.
DOT 4 SL.6 is specified and perfect for the application. My 3 year service is coming up in July so the fluid will be changed then. Since I'm not going to be cracking open the brake lines to do the rotor swap, there's no need to do anything more than check the fluid level after the project is done.
All of those plus NAPA auto parts, and ACE Hardware carries Craftman tools if you don't have a nearby Sears.
The internet has one on the way. Not sure whether the pads or the tool will arrive first, but I expect that both will be in hand before the rotors themselves.
Paul thinks he will ship tomorrow or early next week. Don't know if they're coming by slow boat of air freight.
#28
Calling back to some previous posts I saw: Front pads are massive, and came in a plain box, held together by a rubber band.
Porterfields are in hand (on shelf, to be accurate). I needed a few bits from Snap-On, so added the (paid too much for) the 9mm driver, but it'll be matchy-matchy with most of my other hand tools.
Just one tip - do all the caliper bolts up nice and tight so use a 1/2" socket driver not a piddly 3/8".
#30
I don't usually resort to 1/2" drive until I get to lug nuts or major pieces. I've gone to 3/4" only for really serious ****. What's the torque spec?
#31
#33
Caliper bracket (wot bolts to the hub): front and rear both 115 Nm / 85 ft/lb.
Front caliper bolts (the slide pins, wot you need the 9 mm driver for): 58 Nm / 43 ft/lb.
Rear caliper bolts (15 mm IIRC but could be 12, 13 or 14 mm): 35 Nm / 26 ft/lb.
lizzardo (05-18-2018)
aladamson
03-10-2009 07:36 AM
rajinder75
10-14-2008 10:42 AM
