Start up rattle
Old Nov 10, 2021 | 03:20 AM
dibbyandco's Avatar
Default Start up rattle
Hi all. On start up, while tickover revs are raised, my V6 S has an annoying rattle from the back, underneath. Could be a loose exhaust bracket, loose baffles? Anyone else had this and found out what it was?
Old Nov 10, 2021 | 06:53 AM
Therock88's Avatar
It could be what you described, but you can quickly check to see if the exhaust may be touching the cross supports at mid-pipe or rear...They are very close anyway...Worth a look. Examples below on a AWD R...Others are similar.
Or any number of the heat shields touching..
DC
Carbuff2's Avatar
Could be anything you mention.
Have a shop get it on a lift, and check around.
Ours had a intermittent rattle from the FRONT...bent heat shield from when the O2 sensors were replaced by the P.O.
Old Nov 10, 2021 | 08:02 AM
dibbyandco's Avatar
Thanks both, I'll take a look!
Old Nov 10, 2021 | 04:31 PM
DJS's Avatar
DJS
The active exhaust vacuum pump is behind the left rear wheel, and mine sounds like a buzzing heat shield when it runs. One reason I remove F43…
Old Nov 11, 2021 | 03:48 AM
dibbyandco's Avatar
Interesting, that could be it
David Moffat
Aug 1, 2022 01:43 AM
WaterDragon
Jul 2, 2021 06:01 PM
lossking_
May 20, 2021 02:44 PM
1 of 19
Oct 4, 2015 08:02 AM
Neilpet
Aug 25, 2015 10:10 AM
