Supercharger and rear tire replacement ruined the way my f type drives
Received 3,113 Likes
Maybe, maybe not.
My S has adaptive suspension and the strut top wiring looks very different:
I have pulled the plug out of the top to show how it looks.
Mine has the same pair of wires going to a bolt on front of (to the left) the strut top but it doesn't have the single wire to the left of those (which looks like an earth wire to me).
Maybe, maybe not.
Top of my strut looks like Unhingd's picture. I always assumed that unless you have that connector your car does not have variable damping suspension. So my next question is what is the functionality of height ride sensor is in base F-type and why does disconnecting it degrade ride quality?
So what kind of shocks does base trim F-type has?
#28
I suppose the accelerometers and ride height sensors used by the adaptive suspension might also be use by the dynamic stability control. Though looking through various documents, that doesn't appear to be the case - DSC uses wheel speed sensors, steering wheel position, and lateral/yaw accelerometers.
Base has conventional shock absorbers. Don't recall if active suspension is/was an option on the base or not.
https://www.dropbox.com/s/p8jkgw63ql...nsion.pdf?dl=0
Unhingd (04-27-2019)
#30
#31
QwikCat
XE ( X760 )
08-24-2016 01:57 PM
desert_fox
12-15-2014 12:18 AM
