Turn signal lights stay on
Old Mar 5, 2025 | 03:39 PM
KellyJ1963's Avatar
Default Turn signal lights stay on
2018 F Type- message light that lights are on. It appears that the small yellow turn light stays on even when lights are turned off. Any easy fix or is the a mechanic fix? The tail lights are on too. They were on all night and the car still started so, the battery (1 year old) is still charged.
Thanks.
Old Mar 5, 2025 | 03:52 PM
sov211's Avatar
Your battery is the first culprit! I know, it does not make sense, but low battery voltage triggers all sorts of electrical issues. Before you do anything else, make sure that the battery is FULLY charged. If the battery is more than 5 years old, it should be replaced BUT a new battery must also be fully charged before installation.
Old Mar 5, 2025 | 05:08 PM
KellyJ1963's Avatar
I have heard that. I bought it used, so I will check the battery age today. Thanks!
Old Mar 25, 2025 | 02:31 PM
KellyJ1963's Avatar
Default Parking lights remain on
Turns out, the turn signal unit ($900 plus labor) had to be replaced. Lights go off as normal now.
talashek
Dec 22, 2024 01:40 PM
Patrick 1989 XJS
Nov 9, 2023 10:33 PM
ThatXF
XF (X260)
Jun 20, 2021 03:37 PM
J_C_R
Aug 25, 2018 11:18 AM
Sixt8bird
XJ40 ( XJ81 )
Jun 15, 2015 07:08 PM
