Tyre pressure monitoring system fault
Old Apr 2, 2020 | 02:07 AM
vaibhav's Avatar
Default Tyre pressure monitoring system fault
hi i am getting tyre pressure monitoring system fault and the pressure reading are not being showed
Its jaguar f-type (x152) 2019 MY
any idea how to fix this
Old Apr 2, 2020 | 02:27 AM
Welcome to the forums vaibhav,
I've moved your question from the end of Motselisi's Intro thread of August 2019 to F-Type forum. Members here with the same model will be able to help.
Old Apr 2, 2020 | 03:04 PM
RacerX's Avatar
Banned
Make sure all four tires have exactly the same pressure in them and drive 50 miles. The light should go out on its own.
Old Apr 5, 2020 | 02:14 PM
FType17's Avatar
Go in for a TPMS module software upgrade. Common issue
Old Jun 17, 2020 | 01:33 PM
Unhingd's Avatar
After 35k miles just had this warning pop up. I’m hoping it’s just a software update. At least I still have 2 weeks on the OEM warranty. Otherwise I’d have to pay a $100 deductible on the extended warranty.
Old Jun 17, 2020 | 09:24 PM
Mbourne's Avatar
Had this happen a few weeks ago at 45k miles. Went immediately to a air pump and made sure all 4 tires were at the same pressure. One was 2psi lower than the others. Shut the car off and restarted. Warning cleared immediately and have not had it pop up since.
Old Jun 18, 2020 | 07:48 AM
Unhingd's Avatar
Thanks, I’ll give that a try. You’d think it would just show a low tire pressure warning.
Old Jun 18, 2020 | 05:17 PM
Mbourne's Avatar
considering the one that was 2psi low was at 34psi as opposed to 36 for the others I agree, it’s goofy. I just chalked it up to British quirkiness.
Old Jun 18, 2020 | 07:49 PM
Unhingd's Avatar
Guess what! Also had 36psi on 3 corners and 34 on the 4th. Pumped them all up to 40psi and relieved the pressure back to 37psi. 3 miles down the road, the alerts went away. Thanks Marko! Yet another idiosyncrasy to live with. Damn, I love this car!
NerdAlert
Mar 26, 2020 08:41 AM
DPierce388
Oct 2, 2019 05:53 PM
mlebofsky
Feb 8, 2018 11:49 PM
sest1412
Jun 19, 2011 07:46 AM
