Vibrations in steering wheel
Old Sep 1, 2022 | 01:54 PM
Craaaazzy's Avatar
Maybe try to find someone local who can temporarily swap front wheels just to confirm if it’s wheels/tires. Then continue troubleshooting from there.
Old Sep 1, 2022 | 02:50 PM
DJS's Avatar
DJS
Just making sure it’s not the lane departure warning, which is a very noticeable vibration in my XE.
Old Sep 1, 2022 | 03:28 PM
tjp's Avatar
tjp
Thanks both.
Definitely not lane departure, happens all the time on any kind of road/roads with no lines in the countryside etc!
Not sure how many f type owners carry a spare set of wheels but will ask around.
Any other bright suggestions welcome too. Thanks, it is appreciated
Old Sep 1, 2022 | 03:32 PM
Carbuff2's Avatar
A slightly bent front wheel can cause that type of vibration.
The better Road Force Balancers (Hunter brand) can measure runout of the tires, rims, and assemblies. Otherwise, if you have access to another pair of fronts, fit them and test.
But, see if its Lane Departure, first. Your previous alignment may have resulted in the steering gear not 'centered', and the electronics are now assuming that you are turning the wheel more than you actually are.
Old Sep 1, 2022 | 07:24 PM
OzXFR's Avatar
According to his signature tjp has a 2014 F-Type and no way that early a model has lane departure warning!
Old Sep 1, 2022 | 07:40 PM
Borbor's Avatar
Check the bolts on top of the strut towers as they are often loose. May explain why more noticeable on turning to the left
Old Sep 1, 2022 | 07:45 PM
Borbor's Avatar
If you do end up needing to put two space saver tyres on the front of the car please post a photo as would have a cool dragster look.
Old Sep 2, 2022 | 01:30 AM
  #28
tjp's Avatar
tjp
Will check suspension mounts and get another 4 wheel alignment done. Will ask them to check wheels/tyres specifically for any sign of damage or repair.
I shall report back in a few weeks!
Old Sep 22, 2022 | 03:23 PM
tjp's Avatar
tjp
Update on this one.
4 wheel alignment and balancing done again, this time on a Hunter system and the chap talked me through it.
Front left wheel was miles out in terms of camber and toe, more than 2 degrees! took a huge amount of adjustment to get it back in line.
Steering wheel was off-centre
Front left tyre also shagged, probably due to the terrible alignment, risen edges all the way round which indicates it has been overheating.
All 4 wheels rebalanced and most needed 10-30 grams of weight.
Vibration 75% gone now. Will replace front tyres soon and that should sort it.
The above more than likely caused by Mrs.tjp hitting a pothole she hasn’t told me about on our horrible English roads.
thanks for your help everyone, did appreciate it.
ChrisJay
Dec 2, 2014 07:41 AM
Gnome
XJ40 ( XJ81 )
Aug 16, 2012 04:06 AM
reggie
Jul 14, 2010 04:21 AM
styper526
Mar 23, 2010 08:45 PM
Michigan
Mar 4, 2008 05:04 PM
