Water Meth..
Old Sep 17, 2025 | 12:30 PM
  #81
Stuart@VelocityAP's Avatar
Originally Posted by Lynmup
Does that include the same WMI kit used for the 2300? I'd like to have an apples to apples comparison with the same modifications to the 1.9L as used with the 2.3L to see how much more power you gain with the same fueling available to see the differences. In your videos, you state using WMI is a must with the new 2.3L so that aludes that you were not using it on the 1.9L. The only benefit I see is using the 2.3L to gain more efficiency along with more added fuel to really push the boost where the 1.9L is limited.
I have seen videos of multiple vehicles with roots style blowers making 40-50 additional hp with the WMI so I can only assume the SVR is at least making 40 additional HP. I know I gained .15 seconds in the 1/8th with the additional WMI on my SVR and it feels much stronger. Wallace racing 1/8th mile calculator shows the time difference to be a 25hp gain.
WMI doesn't make power on it's own. It only makes power if you are losing ignition timing due to heat. The 2300 is much more sensitive to heat because the screws are longer. The benefit of WMI on the 1900 is a lot lower than it is on the 2300.
So, it's not simple arithmetic like:
1900 = X
WMI = X + Y
2300 +WMI = X + Y + Z
In much the same way that we've gained around 15 BHP with our carbon intake + V8 MAFS on the 3.0L. That's when we are ALREADY at 600BHP. Putting that intake on a stock 340BHP XE isn't going to yield the same gains.
What I can definitely tell you is this - I've driven.... pretty much everything under the sun on the 3 & 5L platforms. Every combination of Mods, multiple platforms. Even driving our FPace SVR with the 2300 kit and NO WMI, it was noticeably faster than the modified 1900. Just the low & mid range torque delivery is very different.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Sep 17, 2025 | 12:39 PM
  #82
Lynmup's Avatar
1900 = X
WMI = X + Y
I follow you on that! There is more efficiency on the 2.3L so the WMI injection will net even more gains with the 2.3L. I WILL be buying the 2.3, just want to get more out of it than the 50ish HP I believe it to provide until more fueling options are provided. I do not disagree that it gives much more under the curve power as well. It's not always peak that is important, specifically one a supercharged application whereas the off the line torque makes a huge differnece as well. That is someting I love about the Jaguar, the immediate throttle you get when you give it gas is amazing.
Sounds like I have a winter project I can work on once the Yukon is runing again.
Old Sep 17, 2025 | 12:46 PM
  #83
Lynmup's Avatar
...The benefit of WMI on the 1900 is a lot lower than it is on the 2300...
I purchased everything I need to install parts on the lid of the supercharger, just not sure it would be of great benefit. What is your advice on that? I am currently running a #14 nozzle before the throlttle body as shown in my earlier picture. Would using one #4 nozzle on each side of the lid as Terrance39 did and one #10 at the throttle body help any? Or perhaps two #2 nozzles on each side of the lid to get more WMI into the cylinders? Don't want to have multiple holes in the lid to determine the best placement.
Old Sep 20, 2025 | 12:09 PM
  #84
Lynmup's Avatar
..With your pulley ratio yes, you might too far out of the efficiency range.
So Stuart, do you think it would benefit me more if I went back to the 62.7mm (2.468" ) pulley vs the smaller 60.96mm (2.4") pulley? If I'm out of effenciency then perhaps, all my WMI is doing is combating the heat and not really adding and beneficial power gains.
**Note to others***
I put my VAP upper back on and am seeing more power and boost in my VAP data logging software and with zero knock retard. This 1.9L is very limited on the boost levels so be aware when trying to chase more power.
Old Sep 29, 2025 | 12:19 PM
  #85
**Note to others***
Although we don't purport to know everything and try instead to show everyone full transparency about what we do/don't know, we have done a LOT of R&D, datalogging and verification and that has informed the decisions we have made about how to structure the tuning products. We love that people want to push the envelope, but that doesn't always yield results if it doesn't have the right combination of parts & supporting modifications.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Sep 29, 2025 | 12:25 PM
  #86
Lynmup's Avatar
And that's why you are my "go to" for anything Jaguar performance related. After swapping to the original stage 3 upper pulley, I was able to pull a bit more E85 in it as well and it's doing great. Getting the cats removed on Thursday, can't wait to see how that performs.
Old Oct 16, 2025 | 11:41 AM
  #87
Lynmup's Avatar
***Update***
I had high flow cats installed as the cat delete was extreamly loud and unpleasant, sounds and performs perfectly.
1st run with the 60.96mm (Griptec) pulley and stock cats ----- 1.7539 - 0-60 ft _ 4.9195 - 330 ft _ 7.5034 ET _ 95.46 mph (1/8 mile track run) E25
2nd run with the 62.7mm (VelocityAP) pulley and cat delete ---1.7588 - 0-60 ft _ 4.9425 - 330 ft _ 7.5278 ET _ 95.34 mph (1/8 mile track run) E30
3rd run with the 60.96mm (Griptec) pulley, high flow cats, ------- 1.78 - 0-60 ft ___ 4.87 - 330 ft ___ 7.43 ET _ 93.19 mph (1/8 mile Draggy run) E30
I will go to the tack once more and update the final comparison.
cbroth1
Oct 29, 2025 08:52 PM
JayJagJay
Jul 5, 2020 07:59 AM
orangeblossom
Jan 15, 2017 08:28 PM
orangeblossom
Oct 26, 2016 12:01 AM
buickfunnycar.com
Nov 21, 2014 11:16 PM
