You want to run around a negative 2-2.5 degrees in front . The rear is not adjustable but you can get it out to about neg. 2.5 degrees if you lower it with the H&R springs. The VAPs will probably get you to neg. 2.25 degrees.
Getting the extra camber surprisingly will have little to no effect on your track times. But, the suggested 2 - 2.5 on the fronts will help immensely with tire wear as the fronts get worn out on the edges.
