Yet another oil overfill.
Yup, happened to me, V6 RWD. And I just drove 150 miles like that. Waited 15 min before checking. Guess I'm going to re-read all the threads on this subject tomorrow. It's 2 am now, good luck to me getting any sleep.
https://cimg5.ibsrv.net/gimg/www.jag...15de6b1d3f.jpg |
Have someone with an extractor take some oil out - probably a quart, then use the electronic dipstick. You can get an extractor good enough for the job pretty cheap.
Don't start it up and drive to the dealer. Was it a dealer that did this? |
Yup, dealer. Thanks, I have to pull the plug on tonight, will look again tomorrow.
No excuse for that on a RWD car. I'd tell the dealer to send someone out to your house with an extractor.
This happened to me as well at a dealership. Jaguar should have sized the US sump to take an even number of quarts - or should calibrate their sensor to allow a little bit more oil in the pan. It's probably an insignificant amount, but without a real dipstick you have no way to tell.
Thanks folks. So I just checked it cold and now it says OK?? I would think that cold, will all the oil drained into the pan, it would read even higher??
Originally Posted by Misujerr
(Post 1848464)
OK, that makes sense, thanks once again.
(Post 1848464)
I suppose running the engine up to operating temp and rechecking might 'prove' that? |
Thanks mshedden. I think that 0.4 q over is a LOT. I just checked the manual and it specifies to check the oil just the way I did. So I'm going back to my original statement that is is overfilled. Calling those mofos in the morning.
(Post 1848602)
A slight deviation: is there any reason why the oil cannot be checked with the oil cold? When I do this the graph shows the oil to be full, just as I would expect. And I have always checked the oil in my cars after allowing the engine to sit overnight - the idea being that an accurate measurement requires that the oil return fully (or as much as possible) to the sump. So, is a cold measurement not advisable for any particular reason?
My manual says the oil should be hot, but to wait at least 10 minutes after the engine is shut off. Which means I don't check it often, as that's a bit awkward.
1 Attachment(s)
Originally Posted by DJS
(Post 1848669)
and why is the photo turned on its side???? Can it be straightened? |
Originally Posted by sov211
(Post 1848691)
Yes, but the waiting for a period of time is to allow the warm/hot oil to drain back into the sump. So the question is this: given that I have waited long enough (much longer) to allow all the warm/hot oil to return to the sump, of what importance now is the temperature of the oil? The oil does not need to move further to be measured. I am just trying to understand a) the concept and b) the reason why a cold measure would not be valid.
Originally Posted by mshedden
(Post 1848704)
The warm oil occupies a larger volume because it expands with increased temperature. If it measures 'full' with warm oil, it will measure 'low' with cold oil.
However, reading information here (full detailed info) Jaguar Owner Information ^^^^^^ I am not sure what do they mean by If the message ENGINE OIL PRESSURE LOW is displayed in the Message center, stop the engine as soon as it is safe to do so and seek qualified assistance. Do not start the engine until the cause has been rectified. |
Pretty sure "engine oil level low" and "engine oil pressure low" are completely different warnings", although the first problem (low oil) could result in the second problem (low pressure).
Also, I understand that the car will not / cannot warn you of low oil level other than you checking the electronic level readout yourself (ie it's manual not automatic), but it will automatically flash up the "low pressure" warning if it detects low pressure. |
If Unhingd says it's good, I'll go with that. I def want to get it sucked out though. Now I am wondering whether to suck it out myself or have the dealer do it. I don't think I want a potential buyer of the future seeing "overfilled" on the carfax...
I have seen some posts where the sent a tech down or flatbedded it to the dealer. This one is about 50 mi from me.... |
(Post 1848773)
I have seen some posts where the sent a tech down or flatbedded it to the dealer. This one is about 50 mi from me.... That said, if you invest a few $$ in a hand pump so you can remove oil, or even do your own changes if you want, then more power to you. |
I always check the oil cold and look for it to be at 1/2 to 3/4 on the scale.
