2002 xj8 vvt unplugged
Old Mar 11, 2019 | 04:44 AM
jasondemars's Avatar
Default 2002 xj8 vvt unplugged
Im doing an aj26 swap into an aj27 car. I've swapped out the pickup on the back of driver side cam and added one to the passenger side cam. changed the main harness and kept all the 27 stuff on the 26 including the oil sump with both oil sensors and swapped the flywheels. What i would like to do is delete the v v t system on the 26 by putting the aj27 front cover on and using the 26 valve covers and essentially leaving the v v t unplugged. My question is : By leaving the sprocket on but deleting the bush carrier and the solenoid , do i need to plug the oil holes that fed the v v t or can i run as is? The car is a dd and im sure fuel economy will go down slightly but what I'm really asking is: Will the car go into limp mode/ restricted pro over unplugged vvt or will it just have the yellow dash light working overtime?
Thanks Jason in Tennessee
Old Mar 11, 2019 | 07:27 PM
I really need to know if xj27 will go into limp mode with the v v t unplugged.
Old Mar 12, 2019 | 05:08 AM
Anybody please.....
Going to be putting engine back in soon
Old Mar 16, 2019 | 08:18 AM
motorcarman's Avatar
I'm sure you will have VVT codes.
Jaguar issued a TSB for the oil passage in cylinder heads.
You will be going the 'other-way' with the oil passage.
bob
File Type: pdf
02jagstype
Sep 4, 2015 08:20 PM
innzane
Apr 13, 2015 08:58 AM
AlbBolivar
Apr 3, 2015 12:09 PM
Quebecjag
Oct 22, 2013 08:01 AM
cooke
Sep 11, 2010 04:25 AM
