Adding oil to XF Supercharged?
Old May 22, 2019 | 08:48 PM
kenmicn's Avatar
Default Adding oil to XF Supercharged?
Hello,
I bought a XF Supercharged (2009) this past January. I want to know how to add oil to the engine. Seriously; the cap seems to have a unique way of opening--simply "twisting" the oil cap doesn't open it--how can I open the cap to add a little oil and some oil additive? Is there a video anywhere that explains this "trick"?
Thanks.
Old May 23, 2019 | 01:01 AM
JagV8's Avatar
If it's as I think then they do just twist off but you can get to the point where it feels like that's not true!
Old May 23, 2019 | 02:38 AM
OzXFR's Avatar
Yep, it's a simple twist off counter-clockwise.
If yours won't come off with a gentle twist then it might be a little stuck with old/burnt oil or the cap might be faulty in some way.
Old May 23, 2019 | 07:53 AM
kenmicn's Avatar
Thanks; you are correct; is does feel as if it is not true--I will try again with your note---it must be a very precise turn and getting the cap aligned just at that "sweet" spot for the cap to come off.....
Old May 23, 2019 | 10:10 AM
JagV8's Avatar
I tend to wear (latex/nitrile/etc) gloves - they help with grip as a side-effect.
Old May 23, 2019 | 12:40 PM
Brutal's Avatar
they stick, twist harder
XJsc-guy
Jun 14, 2015 03:49 PM
petemohr
General Tech Help
Jan 2, 2015 08:38 PM
09sleeper
Jul 6, 2014 10:20 PM
PattertiXK8
Dec 4, 2012 04:26 PM
