Adding oil to XF Supercharged?
Hello,
I bought a XF Supercharged (2009) this past January. I want to know how to add oil to the engine. Seriously; the cap seems to have a unique way of opening--simply "twisting" the oil cap doesn't open it--how can I open the cap to add a little oil and some oil additive? Is there a video anywhere that explains this "trick"?
Thanks.
Thanks.
Yep, it's a simple twist off counter-clockwise.
If yours won't come off with a gentle twist then it might be a little stuck with old/burnt oil or the cap might be faulty in some way.
Thanks; you are correct; is does feel as if it is not true--I will try again with your note---it must be a very precise turn and getting the cap aligned just at that "sweet" spot for the cap to come off.....
orangeblossom
Feb 28, 2016 04:35 PM
XJsc-guy
Jun 14, 2015 03:49 PM
