OK here's the latest.
There are four different software platforms depending on which model year of vehicle, and the solution to changing ratio's is different for each one. X308/X100 AJ26 engine - needs a custom-written PCM program X308/X100 AJ27 engine - needs a custom-written PCM program, but it's different to AJ26 X350/X202/X103 (up to 2005MY) - needs a modification to the VID block X356/X206/X150/X250 (2006MY onward) - needs a modification to the CCF The AJ26 is still a work in progress The AJ27 is tested The X350/X202/X103 is tested (VID) The X356/X206/X150/X250 is also tested (CCF) The 2006MY onward cars are the easiest to change. In all cases an IDS/SDD is needed to make the changes. I've had to put the ratio-swap in my car on the backburner because of other projects and my day-job. I'll get around to it sooner or later. |
Thanks!
Interestingly, I've never seen the X356 designation anywhere else but on this subject. Makes sense, just didn't know about it. |
My notes show X356 is XJ 2006-7, uses VID. IDS/SDD has/had/uses/used X356VIDBlock.xml
There are some XJ MY VINs in the Vehicle Spec file but I'm not sure exactly which range. Cambo can probably post more. |
Post more what?
If you hook up an X356 (an X350 from VIN G49701 to H18679) or an X358 (from VIN H18680 to H32732) to SDD it presents you with a CCF... |
That'll probably do - I couldn't find the VIN range quickly.
Originally Posted by Cambo
(Post 1486183)
The AJ27 is tested |
Excellent news!
So no luck on the AJ26 yet? I'm finally bought a VCM Rotunda of my own. (waiting on the shipment)
Originally Posted by adam699
(Post 1493393)
| All times are GMT -5. The time now is 07:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
