Engine Undertrays and Corrosion
Old Apr 26, 2011 | 11:14 AM
xjrguy's Avatar
Photobucket
Default Engine Undertrays and Corrosion
Many folks are aware of this I'm sure, but I just ran across one, and thought I'd pass it along for those that aren't.
S-Types and X350's all have an undertray below the engine. For some reason, [and I have yet to get that reason] Jaguar tacked to that undertray a plastic, foam filled pillow. That pillow traps a horrendous amount of moisture and lays against the steel front cross-member and harbors corrosion, lots of it! Consequently, any such car that lands in front of me has that pillow removed. I then treat the member with an anti-corrosion spray. The damage is usually done, but hopefully it helps. Those cars that I caught early, I'm happy to say, show very little corrosion, even at higher mileages.
Examples are attached. Those that have these models would be smart to check this area out.
Attached Thumbnails Engine Undertrays and Corrosion-x350-undertray.jpg   Engine Undertrays and Corrosion-x350-xmember-02.jpg
Old Apr 26, 2011 | 03:56 PM
plums's Avatar
probably a noise abatement feature
X308 affected?
Old Apr 26, 2011 | 04:05 PM
xjrguy's Avatar
Photobucket
X308 affected?
No, thankfully they don't have a full undertray.
Cheers,
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
