Looking for a great sounding exhaust
Old 06-09-2019, 02:06 AM
Robert Bradshaw's Avatar
Default Looking for a great sounding exhaust
Hi all , I currently have the standard quad pipe exhaust system on my 2010 5ltr supercharged XKr is there a better sounding exhaust system available that doesn’t involve swapping the entire system that gives a louder throaty sound? Thanks bob
Old 06-11-2019, 01:23 AM
henry crun's Avatar
Don't know if this is possible on quad exhaust XKR's, but I found that the best way to release the V8 throb on my V8 XJ Sovereign, XJR and Super V8 cars was to remove the front (common) muffler to separate the V8 exhaust beats. The rear mufflers can then be removed to increase volume if required. I found that increasing pipe diameter had little effect on sound.
This inexpensive mod produces a satisfying muscle car throb on acceleration, without excessive drone on cruise.
Old 06-17-2019, 09:59 PM
jeffu's Avatar
henry crun - are you a talking about the muffler I have circled in red? Sorry for the 2 stitched photos. This is the under belly of my 2010 XKR I took today.
Old 06-18-2019, 04:07 PM
henry crun's Avatar
Yes - that's it.
This front box is not really a muffler. It is more of a resonator with 2 straight through perforated pipes inside a common cover filled with sound absorbing material. It has zero effect on performance, but acts as a crossover (e.g. H pipe) to blend the two exhaust pulses for acoustic 'smoothness'. This blending produces the traditional Jag 'growl' to emulate the original British 6 cylinder Jag sound.
If you prefer the V8 throb, replace this box with 2 straight pipes. For increased volume, remove (or replace with straight pipe) 2 of the rear boxes (which are true mufflers) unless your car has bi-modal exhaust valve system).
Despite what some other posts claim, the AJ V8's have the typical 90 degree cross-plane crankshaft and firing order so they sound the same as any other cross-plane V8 with an unrestricted exhaust. This cross-plane crank and firing order configuration produces the distinctive 'throb' because of the exhaust valve opening 'overlap' of the rear 2 cylinders of each bank. I.e. exhaust valves of the 2 rear cylinders are open simultaneously for a brief period, which produces a relatively larger exhaust pulse into the exhaust manifold, which alternates from bank to bank. The front exhaust resonator is designed to blend these pulses and smooth the throb.
Old 07-05-2019, 07:35 PM
Reverend Sam's Avatar
Received 1,257 Likes on 563 Posts
Fixed it.
jeffu (07-07-2019)
Old 07-06-2019, 03:54 AM
GGG is online now
Received 16,747 Likes on 12,140 Posts
Originally Posted by Robert Bradshaw
Hi all , .....
Welcome to the forums Robert,
I've moved your question from General Tech Help to X150 forum. This is the place to post technical questions about your model.
Old 07-06-2019, 08:27 AM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
If you "want the best", Larini considered top shelf for any marque they make an exhaust for. There are a few British manufacturers that you should consider too.
Old 07-06-2019, 08:51 AM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
It all comes down to what is your budget and what kind of sound are you looking for. There are different sound clips on this form as well as on youtube. Start by looking at these to see what fits your needs. Also instead of hacking up your existing exhaust just go to a good muffler shop and have new pipes made up. I would suggest the 1st phase would be to remove both of the center silencers. You can replace with 2 straight pipes and then pull fuse 19 for the valves in the back box. If still not happy you can have an X pipe installed and the next step would be an aftermarket cat back system.
Old 07-06-2019, 10:21 AM
Cee Jay's Avatar
Received 5,145 Likes on 3,082 Posts
LOTS of XKR guys do what Henry Crun suggested; remove the resonator section and have two straight pipes with an "X" crossover installed. If it's done competently, you still have the entire center section you can replace if you ever want to go back. Total cost to have a muffler shop do this is like $200-250, compared to the multiple-thousands that a new system would cost.
Plus..... you DID remove fuse 19 from between the rear seats, RIGHT??????
Old 07-07-2019, 12:07 PM
jeffu's Avatar
Nice touch to my pictures Reverend Sam! Looks a lot better!!
Old 07-07-2019, 12:58 PM
Thanks for the great information I’ll look into this and yes I removed a fuse although I cannot remember the number
Old 08-24-2019, 09:08 PM
Billieg's Avatar
How do you find that fuse?
Old 08-24-2019, 09:20 PM
Cee Jay's Avatar
Fuse panel behind the rear seats, between them. Pull up, then out, then up again on the center back section and it'll come off eventually. The fuses are numbered so it's easy to find. That fuse controls the vacuum which holds the secondary pipes closed, so therefore OPEN all the time.
Billieg (08-24-2019)
Old 08-25-2019, 01:53 AM
Sovejag13190's Avatar
Hi i think that i'm going make this on my xkr 2007 :
Old 08-26-2019, 07:39 AM
guy's Avatar
guy
guy is online now
Received 1,001 Likes on 709 Posts
Face the music: catalytic converters do become less efficient over time.
Want an improved sound too: Just replace your cats with 200 cell cats. remove fuse 19 and live with it for a week. Then tell me what you think.
Consider the x-pipe AFTER this suggested change.
FWIW
Old 08-26-2019, 11:34 AM
Billieg's Avatar
FWIW
Thanks, I'll try that. So the #19 fuse is it behind the rear seat so you have to take the seat out?
Old 08-26-2019, 11:42 AM
Cee Jay's Avatar
Post 13?
Sheesh, sometimes I wonder why I post useful information
The following 3 users liked this post by Cee Jay:
guy (08-27-2019), MarkyUK (08-26-2019), TexasTraveler (08-26-2019)
Old 08-26-2019, 03:07 PM
Billieg's Avatar
Post 13?
I'm sorry but it wasn't clear if the fuse was behind the rear seat or if it was in the trunk behind the rear seat. Why would Jaguar place a fuse box behind the rear seat where it's hard to get to?
Old 08-26-2019, 04:38 PM
Received 4,435 Likes on 2,421 Posts
You say you have a 2006 XK8.
A 2006 XK8 is the model X100, looks like this;
You are posting questions in the X150 forum, an X150 looks like this;
They are totally different cars. There is almost no shared parts or technology between these two models.
The exhaust layout is totally different.
There is no "fuse 19" in an X100, because they did not have an active exhaust.
Please go to the X100 subforum ==>> https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
You will find very little information here in the X150 subforum which is applicable to your X100.
Old 08-26-2019, 04:42 PM
pwpacp's Avatar
Post delete....wrong MY.
Quick Reply: Looking for a great sounding exhaust
