Looking for security/locking module - LJE2600AC/XXX
I have a 2004 Jaguar XK8 that was partially flooded and I am looking for an electric piece that has been damaged and I cannot find a replacement. The car was bought in the USA.
The piece is LJE2600AC/XXX and it is a security/locking module. Any help on where I can find this part would be very helpful! Thank you! https://cimg8.ibsrv.net/gimg/www.jag...38d52b7e96.jpg |
Welcome to the forum niramana18,
The SCLM is no longer available from Jaguar (and was a frightening cost) so it won't be available through dealers and the major aftermarket parts specialists are also showing zero stock. This leaves you with the options of sourcing a used one from a breaker and getting it programmed to your vehicle or using a module repair service. I'd go for the repair option and US based members in XK8/XKR forum will be able to advise on recommended repairers. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
I (wrongly) assumed you were in the USA until you added your location. As I had a breakdown in northern Spain in my XK last September, I know Jaguar expertise in the country is restricted.
This ebay.es listing for a module repairer in California who will ship internationally could work out to be a low cost option if you can't find anything nearer: https://www.ebay.es/itm/REPAIR-KIT-f...-/253142538657 Graham |
1 Attachment(s)
It's important to have the last 3 digits of the part number XXX
Look in the boot for the VCATS label to get the suffix LJE2600AC/XXX. Model years and Coupe/Conv will matter to get the suffix correct. Repairing the original is the safest way to get the correct functioning module. Make sure a used replacement has the same suffix. bob |
Try Jagbits for the part. They are expensive, Direct Autoparts 281-971-3189 or do as I do hit the junk yards,
