MOST issue - Audio Amplifier Module Problem - RESOLVED
Old May 8, 2017 | 09:27 PM
rich_g's Avatar
Default MOST issue - Audio Amplifier Module Problem - RESOLVED
Apologize up front, not a jag, but a 2012 Land Rover LR4. Not getting very far on the rover forums, but hoping someone might be able to help me out here given the similarities and it seems there are more people familiar with programming the modules on this forum.
Currently have a bunch of stuff not working in the infotainment department: navigation, all audio, backup camera, bluetooth. Troubleshot it as far as the audio amplifier module was not sending along the MOST signal.
I installed one of the fiber bypass plugs at the amp harness connector, verified the signal was now getting further in the MOST ring, and now the backup camera works again, but rest is still non-functional. Hoping it is still due to loss of communication with the amp.
I can find several replacement amps in the junkyards (specifically BJ32-19C164-AF, very similar to the "high line" ones in the jags), but if I install a replacement, will it require programming that can only be done by the dealer (or by someone with a functional SDD setup and subscription)?
Any help/suggestions would be greatly appreciated,
thanks
rich
Old May 8, 2017 | 11:40 PM
Cambo's Avatar
A used BJ32-19C164-AF from out of a Jag or a Land Rover will be "plug & play" just put it in, no programming needed.
Old May 9, 2017 | 02:20 AM
Originally Posted by rich_g
Apologize up front, not a jag, but a 2012 Land Rover LR4. ....
Welcome to the forum Rich,
Start off with a Jaguar amp and we could eventually convert you to owning the complete vehicle.
If you go ahead with substituting a used Jaguar unit, please close out the thread by coming back and telling us how it worked out.
Old May 9, 2017 | 07:48 AM
rich_g's Avatar
Awesome, thanks for the reply. I also see some BJ32-19C164-AG's come up in the junkyard interchange searches. Curious if those would also be plug n play (perhaps there is an update to them that has fixed what went wrong in mine)?
Thanks again,
Rich
Old May 9, 2017 | 07:30 PM
Cambo's Avatar
The -AG version is the "same" as -AF, just an update of some sort. Will also be compatible, just plug & play.
If you wanted to go a bit further here, it's also possible to upgrade from the 11-speaker 600W Harmon Kardon system to the 17-speaker 1200W Harmon Kardon Logic7 Surround system. I've done this on a few Disco4 / LR4 now.
If you need to buy a replacment amp anyhow, then why not get a Logic7 version and go for an upgrade...
The Logic7 amp is CH32-19C164-BC or CH32-19C164-BD.
You need the additional speakers, which are available as complete d-pillar trims, plus the center speaker that goes in the dashboard. There is some wiring missing however I have made up some "retrofit harness" to solve that problem.
However you do need some software changes to enable the Surround functions, where are you located? I might know someone nearby who could do it. Or if you have a Nanocom or IID, it's possible to do the software changes with those.
You can also just fit the Logic7 amplifier in place of the non-surround one, it should work the same without any programming, have seen this on several other cars that have been upgraded, as an interim fix.
Old May 10, 2017 | 07:20 AM
rich_g's Avatar
I'm located in the USA. I was thinking about doing just that, but thought that since my truck has a build date of 10/12, from looking at this:
Versions | Jaguar & Land Rover Diagnostics
It would appear I need to use an activated online version of V138 or higher of SDD in order to make any module programming changes. V130 only works up to 8/2012 build dates. Or am I interpreting this wrong? Or does the IID tool get around this somehow?
I can find the AG amps for $100 US, so I may just pick one up and throw it in to get me going for now, while I look for a long term solution.
rich
Old May 10, 2017 | 07:33 AM
Cambo's Avatar
Whereabouts in the USA? I've got contacts in many states who can do this sort of thing.
Stay away from those British Diagnostics clones, bad news & they can't do what you need for the Surround Sound retrofit anyhow.
Old May 10, 2017 | 07:45 AM
rich_g's Avatar
I'm in Maryland.
So the IID can do this kind of module programming without having access to a subscription service? If JLR releases a software/firmware update, does IID provide them?
Sorry for all all the questions, trying to get up to speed on how to interface with/maintain this vehicle.
Old May 10, 2017 | 07:42 PM
Cambo's Avatar
I don't know anyone in Maryland unfortunately, I think the closest would be a forum member in New Jersey, he has a proper working SDD and quite a bit of experience with it.
I'm not really familiar with the IID Tool, I know it can do the CCF editing, but i don't know about module programming capabilities. I use SDD myself.
Old May 19, 2017 | 12:16 PM
rich_g's Avatar
So I picked up a -AG amp to get me going, but same problem. MOST signal does not get past the amplifier. With amp installed, audio/nav/backup camera don't work. If I disconnect the amp and put in the MOST bypass, the backup camera works.
I don't get it, I don't think I could have two bad amps?!
Old May 19, 2017 | 05:17 PM
Cambo's Avatar
Is the amp actually powering up? Can you hear the cooling fan in the amp running.
Maybe no power? There is a fuse for the amp, check the owners manual for the fuse location.
Old May 21, 2017 | 07:10 AM
rich_g's Avatar
I'll have to take apart the back again and see if it is actually powering up. But I have 12V at the connector and I can't find any bad fuses.
Old May 21, 2017 | 07:24 AM
Cambo's Avatar
If you've got 12V then that should be fine then.
With the amp bypassed using a MOST loop and the other stuff is working, it's hard to imagine but yeah two bad amps??? What else I cannot guess...
Old May 21, 2017 | 07:32 AM
rich_g's Avatar
I only get the backup camera to work again when I put in the MOST loop. Everything else stays non-functional.
With or without the MOST bypass, I can't even select audio/video (it is greyed out). I can go into 4x4 settings, and audio settings, but that is about it. I can select navigation, but it never gets past the startup / initialization.
The only other thing I can think of is a bad IAM maybe not actually turning the amp on (along the lines of what you are saying). I have 12V at the amp main power connector, but I didn't pull the wiring diagram to see which pinout is actually the "amp enable."
Rich
Old May 21, 2017 | 07:41 AM
Cambo's Avatar
There are two fused +12V supplies to the amp
Central Junction Box, F41, 5A, a yellow & red wire to the amp
Engine Junction Box, F69, 40A, a fat red wire to the amp
These feeds are on different plugs at the amp, the main power feed is the fat red wire, the "wake up" is the smaller yellow & red wire.
Old Jun 13, 2017 | 04:31 PM
8Devils's Avatar
Default Resolution?
Hello - I'm experiencing the exact same issue. Was told I needed a new Amp but it seems like I will run into the same issue as you. Were you able to find anything else out? Thanks -Sal
Old Jun 18, 2017 | 02:55 PM
rich_g's Avatar
I'm pretty certain my problem is the IAM but I have not yet picked one up and swapped it in (been too swamped with other things). I have 12V main power at the amp, but no power at the amp turn-on connector (actually reading ~.7V) and do not hear a fan running. All fuses check out OK as well. Will post back when I finally get the IAM swapped in.
rich
Old Jun 18, 2017 | 05:51 PM
Cambo's Avatar
Seems unlikely to be the IAM in my opinion.
The "wake-up" power on the yellow & red wire, comes directly from the central junction box, it's battery voltage just like the main power to the amp. If you have different voltages on those two power connections then i would suspect there is an issue with the central junction box. The IAM has no control over that voltage, actually the touchscreen and many other infotainment components are powered by battery voltage via the central junction box, so if the touchscreen is powering up, but the amp no, it pretty much isolates the problem to the wire between the amp and the CJB, or the CJB itself.
Can you try to measure the voltage at fuse 41 directly in the central junction box?
Old Jun 18, 2017 | 06:59 PM
rich_g's Avatar
With truck running, I've got 14V at all audio related fuses (including 41).
I really think it has to be the IAM. With the amp bypassed, I would expect other "stuff" should be working. All the stuff that is part of the IAM is non-functional (bluetooth, navigation, radio).
Unfortunately, the wiring diagram that I have doesn't appear to match with my truck (even though its listed as 2010-2012 LR4) so I can't trace the path to confirm what you have stated.
rich
Old Jun 18, 2017 | 07:40 PM
Cambo's Avatar
Send me a PM with your email address, and the VIN of your car, I can send you the right wiring diagrams.
Swapping the IAM is not always a straight forward deal, you need to get one with the exact same p/n, and ideally from a donor that had all the same features as your car; same level of audio, Satellite Radio, etc. Otherwise you probably have to update the Car Configuration File to the IAM in order for all those features to be available.
For example the navigation maps are stored on a hard drive inside the IAM, so you'd need to get a North American version, otherwise the maps will be wrong,
