OBDII code P0492
2007 XK Coupe - Check Engine light came on. Ran diagnostics and code P0492 appeared - Secondary Air Injection; System Insufficient Flow Bank 2. Any ideas? Is the a dealer required fix? Thanks
Doesn't have to be a dealer but does need someone who grasps what that means and what things to check.
If you don't DIY such then maybe a jag indy is near enough to call. |
