Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   General Tech Help (https://www.jaguarforums.com/forum/general-tech-help-7/)
-   -   Please help me identify this part! (https://www.jaguarforums.com/forum/general-tech-help-7/please-help-me-identify-part-84917/)
AtariJaguar Nov 17, 2012 07:36 PM
1 Attachment(s)
So driving the other day when my faithful 2001 Jaguar S-type overheated, I pulled over and found the culprit, a hose that supplied coolant was dangling and shooting fluid all over the place. I found that the connection had basically rotted off and broke inside the hose. A simple fix but I have no idea what the part I need is called or where to start.
Attachment 226557
The red circle indicates where the connection rotted off, all that glue was a very temporary fix that allowed me to get across town. I appreciate any help.
AtariJaguar Nov 17, 2012 07:42 PM
1 Attachment(s)
Attachment 226556
A picture of the hose removed, arrow points to where the rotted piece used to be.
Gus Nov 17, 2012 07:47 PM
You are looking at one of the manual bleed valves that you should avoid using or attempt to use it will fall apart. It is called the Hose assy upper radiator and the part # is dependent on the engine and vin#. You have another manual bleed next to the expansion tank.
Link http://jagrepair.com/images/AutoRepa...DiagramGJG.jpg
MartySchwartz Nov 17, 2012 08:51 PM
I had the same kind of assembly in my 2001 Lincoln LS and suffered the same failure. That part, on my LS, was not replaceable by itself and I had to buy a completely new hose assembly. Considering the condition of the plastic, once I got it off, I was very glad I did not try to "fix" it.
Marty...................
AtariJaguar Nov 21, 2012 03:13 PM
Thanks a lot, I went ahead and bought the new hose assy, anything I should know before removing and installing one?
© 2026 MH Sub I, LLC dba Internet Brands
