SDD Pinpoint Tests
I'm trying to resolve a couple of issues on my car just now, one being a MAF related code. SDD (v131) is suggesting I run a pinpoint test related to that code.
What does this do - does it just guide the operator through checking specific pins on specific connectors for volts/resistance and give a diagnosis there, or can it test bits of the car itself to work it out? Is it safe enough to do, obviously with an approved interface cable and a battery support unit attached? |
Pinpoint tests are only possible with a VMM.
Ah OK, thanks for that.
Sorry to raise the deads but is there a cheaper alternative nowadays to VMM ?
Some of the pinpoint tests identified in the service manual can be done with a standard voltmeter but obviously depends on the tests. Other than that, what Cambo said...
Ok thx i gonna look but i need first to pinpoint technical info about pinpoint test for x type my2009
