I-Pace Level 2 Charging - Specify times through Jag App?
I will be picking up my I-Pace HSE in 2 weeks. I am currently considering Level 2 EVSE's - and trying to decide whether I need the more expensive ones with WiFi/Apps of their own.
Does the I-Pace and/or Jaguar App allow for charging only during certain times, to take advantage of off-peak electricity rates? Or will I need to have a connected Level 2 charger to do that? |
As of right now that is something that is handled by the charger, though I think it could be handled by the car with a level 2 (it just isn't a feature I'm aware of). This may be a safety requirement but that is just speculation.Rob
I'm in error under preconditioning settings you can set charging times. |
Originally Posted by enderle
(Post 2018566)
It depends if you want to keep track of your charging usage.
I, reluctantly, went with the Chargepoint level 2 charger. I say reluctantly because Chargepoint requires you to enter a credit card to use their app (gave them a 1 star review on Amazon). But I bought it because my employer has them in their parking lot and I can charge for free while I work. I get notified via the app when my charging time is up and if there are other people waiting I move my car. When charging at home if you enter your electric utility rate you can track the cost also. As for preconditioning, it only warms the battery not the windshield heaters. |
I changed my answer on charging control, went into the preconditioning settings to see if I could make selections and I can't but found I could set charging times in a sub menu. So you can control charging from the car. Not sure of the logic for putting this under preconditioning but I've noticed a lot of the settings aren't in places that seem that intuitive.
Here is a link to a video that showcases both charging and preconditioning capability: |
(Post 2018998)
Here is a link to a video that showcases both charging and preconditioning capability: https://www.youtube.com/watch?v=Bc7NOrIMhzg |
Uncertainty over charging scheduled by I-Pace
in my Jaguar I-Pace I can specify the charging times which it calls “preferred” times, but it doesn’t seem to make anything happen.. I’m using the Hypervolt scheduling instead which works. I’m left uncertain whether the Jaguar scheduling is functional.
