Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   Interior (https://www.jaguarforums.com/forum/interior-21/)
-   -   Removing glue off of inside rear window (https://www.jaguarforums.com/forum/interior-21/removing-glue-off-inside-rear-window-129068/)
jphurlman Oct 18, 2014 06:34 PM
I recently bought a 2004 XJ8 and the previous owner removed a decal or sticker from the inside rear window, about 4 inches square, leaving the glue residue on about 4 of the defroster elements (lines). How do I remove the residue without damaging the elements.
GGG Oct 20, 2014 03:56 AM
The heating element is first screen printed onto the glass and then fired on during the annealing process so it's fairly robust. (I used to run a plant manufacturing auto glass many years ago).
Your wife's nail varnish remover on a soft cloth should clean any adhesive residue off.
jphurlman Oct 20, 2014 02:20 PM
I have an adhesive remover pad with the following ingredients, will the small amount of silica be an issue? Thank you very much for your response.
Prep-Pad saturated with 70%
isopropyl alcohol and 0.01% precipitated silica
GGG Oct 20, 2014 03:26 PM
The 0.01% precipated silica content will be present as a very mild abrasive. Allow the solvent to do the work without rubbing too hard.
jphurlman Oct 21, 2014 07:34 AM
Response to help
Triple"G"
Thanks again for your help and I will tread lightly and wipe off gently often with a mf towel.
Jim H
© 2026 MH Sub I, LLC dba Internet Brands
