Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   Interior (https://www.jaguarforums.com/forum/interior-21/)
-   -   Weather Stripping Care (https://www.jaguarforums.com/forum/interior-21/weather-stripping-care-169871/)
daddylogan Sep 24, 2016 02:23 AM
So what do you guys do to treat the weather stripping on the door jams and trunk so it stays flexible and looking good plus avoid cracking? Just curious...thanks.
peace out,
daddylogan
omgimali Apr 14, 2017 12:46 PM
WD-40 Silicone did it the other day went over it twice and it protects it. Make sure you do it under the bonnet as there is the most heat there.
Don1954 Sep 26, 2017 02:49 PM
I would not use silicone of any type. WD40 Silicone, by design, is made for metal. As it states in the advert.
I use 303 Rubber Seal Protectant which, as seen below, is for rubber only.
I'd like to know what the Brits are using though! Or for even more fun, what are the Welsh using to protect their rubber?!
303® Rubber Seal Protectant
https://www.goldeagle.com/sites/defa...?itok=rkx1QOIc
  • Conditions rubber seals on doors, windows, hoods and trunks
  • Protects against drying and cracking in extreme temperatures
  • Rejuvenates color to old seals, restores elasticity
ClassicCarFan Feb 19, 2018 04:26 PM
Wow, I didn’t realize what a difference that it could make to try out something like this to keep my door jambs working the way that they should. Is it still a good idea to try that rubber stuff, or does anyone else have other suggestions on what could be best for similar needs? I’m starting to notice some issues with my door as my Jag ages.
heathfieldmotors Apr 12, 2018 03:51 AM
Rubber Seal Protectant is an easy, convenient way to keep the rubber seals of doors and windows, apply it to the weather stripping in your car using the attached foam applicator.
Prange Jun 8, 2018 09:00 PM
Gummi Pflege is the best stuff I’ve used.
303 makes great products.
© 2026 MH Sub I, LLC dba Internet Brands
