Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Difference between AJ16 and AJ16 supercharged
Old Jun 9, 2025 | 12:58 PM
RoseGardener's Avatar
Default Difference between AJ16 and AJ16 supercharged
Could someone please share knowledge on AJ16 engines? Can one bolt a supercharger from an AJ16 supercharing engine to a normal AJ16? I am considering buying a late-model XJS with a 4.0L AJ16 engine, but I would love to have the extra punch of a supercharger. One could swap an AJ16 supercharged from a XJR but could one just swap in the supercharger?
By the way, did both engine came with same 4 speed GM tranny or different?
Old Jun 9, 2025 | 03:50 PM
Cafcpete's Avatar
The short answer is NO. The block doesn't have the holes needed for the supercharger machined. There are quite a few differences. This question has already been answered in the X300 forum.
https://www.jaguarforums.com/forum/x...needed-270627/
And the transmissions are different. Only the SC and the V12 have the GM unit, the normal 4.0 has a ZF 4 speed which wasn't considered strong enough for the extra torque.
Good luck and search the X300 forum as that is were all the info you need is
NeilTrama
XJ40 ( XJ81 )
Jul 4, 2024 06:22 AM
sanchez
May 25, 2023 08:18 PM
XJDanny
Mar 12, 2023 10:34 AM
jesus perez
May 7, 2019 08:46 PM
scarbro2011
Mar 27, 2016 04:41 AM
