Fule injector transplant
Does anyone know if the "new" AJ gen III multi spray fuel injectors fit in a AJ34S engine. If so would the spray pattern produce more power as it does in the 5 liter engine?
The 5.0 injectors are operating at 150 bar and are direct injection, not something you can use. The 4.2 injectors are already very good ones, have 12 nozzles for fuel atomization (in a v shape so 6 to each valve) and operate ate 63 psi.
