Jaguar xf motor install range over parts swap over ?aj126
Hello anyone can tell me the parts need to be swapped over from a Jaguar 2017 xf motor v6 3.0 to fit a 2016 Range Rover 3.0v6 si see the jag motors motor available lower miles and bit cheaper.
Originally Posted by rangemb3
(Post 2730687)
If so I seem to recall that at least the sump needs to be changed over (different size and shape sump for AWD vs RWD) and maybe a metal boss on the XF motor needs to be ground down a little for clearance. Can you see both motors side by side out of the car(s) so you can closely compare them? |
I was told the oil pan and oil pick up and manifolds and wire harness
yea it’s off a 17’ ftype rear wheel not sure if the oil pump or any other accessories need to be changes also possibly crank pulley I just purchased the motor today on eBay and trying to get a head start before it comes Thank u |
I’m just thinking out loud here but, I suggest you proceed with caution. Camshaft profiles and cam phasers can have differences going from one platform to another. Yes, I know it’s still a JLR engine but, your ECM will detect different behaviors from the new heart transplant. The ECM will be used to one reading and it’s likely to get another type of reading which will be possibly out of that said parameter. What I’m ultimately getting at is that when you get the oil pan/pickup situated and the engine installed, you could get several engine codes, reduced power mode and possibly a slew of other issues all related to the transplant. I’ve been in situations where an engine that I had to install wasn’t of the correct year and model vehicle but having to ‘make it work’. I know what it’s like to do a ton of work and realizing I have many obstacles to overcome and in some cases, having to remove the engine and backtrack the whole process. I just wanted to give you a heads up that this can possibly go sideways. I want to you succeed with the replacement and hope it goes well.
Cheers! |
Thanks for the response I had a buddy do a motor swap of the same issue and he installed the jag motor in the Land Rover after swapping all the necessary parts over flashed the computer and no issues. I will be installing the engine later this week so I will stay tuned
That’s awesome! Hopefully your buddy is close by in case you run into any snags.
Any updates?
So, you bought a used car that blew its engine within 2 days?
Surely, even your used vehicle came with some sort of minimal warranty? Just get you money back. It should be the dealer's problem. Personally, I i would run away from the car and get a lawyer if necessary to get your money back. You were knowingly or unknowingly sucker punched by the dealer. It should not be your problem to sort out how to repair it. The more you get involved, the less chance you have of getting financial satisfaction. |
(Post 2730687)
I having the same issue with my range any advice with fitting the jag engine to the range thanks Tc |
Did u get it installed and running?
(Post 2732364)
Hey good morning. Any updates on the install (jag engine to landrover)? Think i need to do the same. |
| All times are GMT -5. The time now is 04:26 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
