Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   Jaguar Engines & transmissions (https://www.jaguarforums.com/forum/jaguar-engines-transmissions-47/)
-   -   Purchased a 3 1/2 engine with a Moss transmission (https://www.jaguarforums.com/forum/jaguar-engines-transmissions-47/purchased-3-1-2-engine-moss-transmission-277883/)
jayd2 Feb 28, 2024 07:11 PM
Yesterday, I pulled a 3 1/2 engine with a Moss transmission from a 1959 MKI.
The 3 1/2 engine is a much earlier engine than what was used in 1959 MKI, correct?
The engine is not totally locked and will turn a few degrees easily. The transmission also has an overdrive.
Glyn M Ruck Mar 25, 2024 04:40 AM
The engine marked 31/2 litre is a 3.4. It's how they were marked.
Mguar Jul 10, 2024 09:50 PM
The 3&1/2 liter engine was Jaguars 3.4 ( as has already been said). So it can date from 1948 through 1959. The color of the head and casting marks will tell you more. However an overdrive transmission wasn’t in use until about 58-59. ( I’ll have to check that to be sure .
Mguar Sep 12, 2024 09:23 AM
It sounds like a 1957-58.
It will work and bolt in where the 3.8 was.
Slightly down on power. Unless the head has a big C cast onto it then it could be from an XK140 MC ( the carbs are sand cast 2”. Instead of 1&3/4
sony2000 Jun 25, 2025 09:07 PM
Does Ford have the 4.2L available? Just the block, pistons, and crankshaft. Then add your parts. They are good.
© 2026 MH Sub I, LLC dba Internet Brands
