Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   Jaguar Engines & transmissions (https://www.jaguarforums.com/forum/jaguar-engines-transmissions-47/)
-   -   Ran hot (https://www.jaguarforums.com/forum/jaguar-engines-transmissions-47/ran-hot-287201/)
ycjones Jan 30, 2025 03:30 PM
Ran hot
2013 jaguar xjl ran hot and melt my gasoline and I had the gasoline replaced but now water is leaking from somewhere underneath but could my head be cracked? And where’s the water coming from?
NBCat Jan 30, 2025 06:34 PM
I'm not sure what 'melt my gasoline and I had the gasoline replaced' means.
If the engine has been overheated, most likely the head gasket(s) failed. The AJ133/AJ126 don't like to be overheated.
With the engine cold, perform a cooling system pressure test to determine the source of the leak(s).
© 2026 MH Sub I, LLC dba Internet Brands
