Remanufacturing - Automatic Transmissions
On 29th March 2014, UK Region were invited to tour Mackie Automatic Transmissions in Glasgow, Scotland.
Mackie Automatic remanufacture torque converters for use on ZF OEM contracts. They are an "A1" rated supplier, the only company in Europe to receive this accolade. They are also the only Scottish distributor for ZF parts and transmissions. The tour was a great success and greatly enjoyed by those who attended. Automatic Transmissions are a mystery to many of us and the information we learned on the day may be of interest to other members around the World. Owing to the numbers attending, we were divided into three groups for our tour of the facility. Each group was able to see the three principal services offered by Mackie Automatic & Manual Transmissions: 1. Remanufacturing - Automatic Transmissions 2. Remanufacturing - Torque Convertors 3. Servicing, Diagnostics and Repair The following three posts cover each of these services.Graham |
Mackie Automatic & Manual Transmissions remanufacture automatic and manual transmissions, gearboxes and torque converters for the public, dealerships and manufacturers.
They accept transmission units delivered to them or take complete vehicles where they will diagnose faults, remove, overhaul and refit the transmission. https://www.jaguarforums.com/forum/a...p;d=1396255081 Owing to the numbers attending, we were divided into three groups for our tour of the facility. Each group was able to see the three principal services offered by Mackie Automatic & Manual Transmissions: 1. Remanufacturing - Automatic Transmissions 2. Remanufacturing - Torque Convertors 3. Servicing, Diagnosis and Repair 1. Remanufacturing - Automatic Transmissions The automatic transmission is totally dismantled and every component is cleaned and prepared for inspection. https://www.jaguarforums.com/forum/a...p;d=1396255194 From this point on, the entire process is scrupulously clean. https://www.jaguarforums.com/forum/a...p;d=1396255211 Each component (several hundred of them) is then examined and measured. All components that are not deemed 100% perfect are replaced. All seals, gaskets, filters high failure components are discarded and replaced with new parts. https://www.jaguarforums.com/forum/a...p;d=1396255225 https://www.jaguarforums.com/forum/a...p;d=1396255241 The valve body (control unit) goes through a process that includes ultra-sonic cleaning, vacuum testing, solenoid remanufacturing and final calibration on a unique valve body test station. This ensures that the valve body meets or exceeds the original manufacturer’s specification. https://www.jaguarforums.com/forum/a...p;d=1396255256 Following component checking, everything is laid out ready for rebuilding the valve body. https://www.jaguarforums.com/forum/a...p;d=1396255270 For those of us less familiar with the parts in the valve body, this graphic gives a clue to how it all goes together. https://www.jaguarforums.com/forum/a...p;d=1396255283 https://www.jaguarforums.com/forum/a...-2014-m_06-jpg During the transmission assembly process, all sub-assemblies are pressure-tested to ensure total hydraulic integrity. https://www.jaguarforums.com/forum/a...p;d=1396255300 The remanufactured valve body is pressure tested https://www.jaguarforums.com/forum/a...p;d=1396255312 Each individual gear is subjected to testing. A loss on any one results in the valve body being put through the full strip, check and rebuild sequence again. https://www.jaguarforums.com/forum/a...p;d=1396255327 Final calibration with data acquisition is carried out on a unique valve body test station. This ensures that the valve body meets or exceeds the original manufacturer’s specification. https://www.jaguarforums.com/forum/a...p;d=1396255342 The subassembly is checked through all gear changes prior to final assembly. https://www.jaguarforums.com/forum/a...p;d=1396255360 The complete transmission assembly has a final build test on one of two road test simulators that create real life driving situations. https://www.jaguarforums.com/forum/a...p;d=1396255403 During this stage, the transmission is run at normal operating temperatures for several hours. https://www.jaguarforums.com/forum/a...p;d=1396255427 The simulator assesses every fundamental part of the remanufactured transmission. Any failed part will instantly be flagged on the test report. https://www.jaguarforums.com/forum/a...p;d=1396255445 This test procedure almost eliminates any potential failure prior to installation to the vehicle. The equipment used by Mackie Automatic & Manual Transmissions is exactly the same as that used by the original manufacturers. Graham |
2. Remanufacturing Torque Converters
Mackie Automatic Transmissions torque converters are supplied with a life time warranty for the vehicle that they are installed in. To start the process, the two welded halves of the converter are cut apart by specialist lathe operators. https://www.jaguarforums.com/forum/a...-2014-m_00-jpg After washing and examination, the unit is re-machined in one of three adapted high-specification lathes to refinish the joining faces. https://www.jaguarforums.com/forum/a...-mackie-17-jpg https://www.jaguarforums.com/forum/a...-mackie-18-jpg Mackie Automatic Transmissions remanufacture torque convertors from the BW66 of the early 1970's through to the current 6HP26. https://www.jaguarforums.com/forum/a...-mackie-19-jpg Through this period, the torque converter has developed from a simple 'fluid flywheel' through increasingly sophisticated 'lock up clutches'. https://www.jaguarforums.com/forum/a...-mackie-20-jpg Note the two beakers on the workbench. The one on the right contains new transmission fluid. The one on the left has typical contaminated fluid from a transmission in for service. Mackie Automatic Transmissions identify where there is a pattern in OE torque converters failures and develop improvements to increase reliability in their units. https://www.jaguarforums.com/forum/a...-mackie-21-jpg The bonded friction lining is removed and a new one is re-bonded to the lock-up plate. This highly specialized process is made possible by a unique bonding machine. https://www.jaguarforums.com/forum/a...-2014-m_01-jpg The torque converter is welded back together, with accuracy to a few tenths of a thousandth of an inch. https://www.jaguarforums.com/forum/a...-2014-m_02-jpg The unit is leak tested to ensure the integrity of the weld is correct and rebalanced to meet or exceed the original manufacturer’s specifications. https://www.jaguarforums.com/forum/a...-mackie-23-jpg https://www.jaguarforums.com/forum/a...-2014-m_03-jpg This equipment test for glycol contamination. Not an applicable part of the process once a transmission has been stripped and cleaned. https://www.jaguarforums.com/forum/a...mackie-23a-jpg The torque converter is shot-blasted to restore a perfect satin steel finish. A coating of anti-rust and an etching identification number is applied to the finished unit. https://www.jaguarforums.com/forum/a...-2014-m_04-jpg The remanufactured torque convertor is guaranteed for the life of the vehicle in which it is fitted. Graham |
Mackie Automatic Transmissions receive complete vehicles from dealers and individuals for everything from the standard fluid change through fault diagnostics and repair to complete transmission remanufacture.
https://www.jaguarforums.com/forum/a...-mackie-27-jpg Our host for the day, Managing Director of Mackie Automatic Transmissions, John Mackie explained that many automatic transmission issues are due to: 1. fluid overheating 2. fluid contamination (with engine coolant) 3. software Autologic is their preferred diagnostics tool. https://www.jaguarforums.com/forum/a...-mackie-24-jpg After retrieving stored and pending codes, these are cleared and the vehicle taken on a 5 to 8 mile drive. Any reset codes are used to diagnose faults. Reflashing the TCM is a routine procedure and the latest updates are always applied. Fluid changes are recommended at 25K miles intervals. This is considerably more frequent than most members are applying to their vehicles. A Hot Oil flushing machine is used. https://www.jaguarforums.com/forum/a...-mackie-25-jpg The fluid lines are disconnected on the vehicle at the cooler and the fluid drained. It is then connected to the Hot Oil machine. https://www.jaguarforums.com/forum/a...-mackie-26-jpg The remaining old fluid is pumped out and the transmission refilled with fresh fluid at the correct temperature and volume. The tour finished with a summary from John Mackie and time for questions. https://www.jaguarforums.com/forum/a...-mackie-28-jpg Not surprisingly, the difference between manufacturer's 'sealed for life' claims for automatic transmissions and Mackie's recommendation for 25K mile fluid changes raised some debate. It is the car manufacturer's (Jaguar included) who claim 'sealed for life'. The transmission manufacturers such as ZF recommend 60K mile fluid changes. John Mackie explained that a more frequent change significantly reduces wear and can more than double the life of an automatic transmission. Not a claim to be taken lightly when Mackie Automatic Transmissions guarantee their remanufactured products for a greater period than the OE manufacturers. Graham |
Great post! Much useful information. Now if I could only find a place like this State side!!
