2002 XK8 ECM and VCATS info
Need VCATS lookup help - 2002 XK8 Coupe VIN: SAJDA41C62NA25123 Looking for original ECM part number with suffix code. Currently has LNG1410BD installed, want to verify if correct. Dealers won’t/can’t look it up. Can anyone help?
Have you looked at your vcats label?
A dealer can't 'look it up'. The JEPC will state that the last 3 digits (suffix) will need WDS to interrogate the module or the VCATS label.
The part number will show up in the JEPC but the suffix will not. What happened to the label in the boot? |
I have looked everywhere in the boot for the label (under carpet, under spare, etc). Cannot find it anywhere. This Jag was my father's for the past 20 years. He passed away, and I am trying to get it running. ECM not working properly, so won't crank. But car is in immaculate condition.
Thanks for any advice. |
How old is the battery? Does it have 12.5V or more with ignition off?
I installed a brand new battery last month.
The VCATS label is in the spare wheel well on all XKs.
The 4.2 liter cars do not have a VCATS because the VID block has all the info. |
(Post 2903372)
| All times are GMT -5. The time now is 07:32 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
