Can't edit sig!
I'm trying to edit my signature, but when I finish and click Save, it doesn't save.
I have the same lines I did before. Is the forum having a bad hair day or what? (';') |
Elinor,
I've added a TEST line to your Signature and it seems to have saved. Please "reply" here so we can see if it really has worked. Graham |
Thank you, Graham,
It did indeed change, but it was Above my picture and not down in the list of Previous fleet where I wanted it. I'll try again now and see it it works for me. (';') |
I just tried again, Graham, and I can't make it work.
I can't remove your TEST line, nor can I add info to the Other Fleet lines. Hmm I wonder what changed since last time I edited that.... (';') |
I've removed TEST EDIT - GGG so your Signature will go back to the way it was.
Can't see why you aren't able to edit. Post the way you want your Others of the fleet to appear and I'll make the change for you. Graham |
Thank you, Graham,
Others of the current fleet: 1974 Dodge 300 One-Ton work truck; "Pockets," so I can roll up on a job fully equipped. 2006 Subaru Baja; "Trucklet," because sometimes you just need a road worthy wheel barrel. 2009 Hyundai Sonata; "Addie," the Adequate Vehicle, when I need a car worthy of any occasion. In the Past; 1969 Datsun SPL-311; "Roller Skate." Not my first car, but Definitely my first love. |
DONE.
It will appear automatically after a few hours but can be "forced" immediately by you making another post. Graham |
Thank you So much, Graham!
