Jaguar MKV oil pressure
Hi,
I'm in the course of restoring my Jaguar MKV to original specs. However as before a Chevy engine was installed I have troubles to locate some of the connections to the engine. On the left side of the engine there is on the oil gallery a 2 way connector, one side is going to the oil pressure gauge, but where is the other side going to? The distributor is having a vacuum advance system, Where does it takes the vacuum from? On the valve cover there should be a valve clearence plate Can someone send me a picture of this plate? (see my previous thread) All help would be highly appreciated thanks Dirk |
