1999 Jag XJR 111k miles
Located in Phx, AZ. Motor and trans are strong. Noise in the rear, which I believe to be the diff. Still drives well though
1999 Jag XJR. Supercharged 4.0L V8. Service history within past year: -updated water pump -Transmission fluid change and pan gasket -Transmission filter -Transmission connector -Differential oil change -Coolant flush -Supercharger oil change and oem coupler -8 New spark plugs -High flow air intake filter -new Valve cover gaskets -2 fuel pumps -2 knock sensors -2 Valley heater hoses -drive shaft couplers -drive Shaft center bearing -front upper Shock bushings -coolant temp sensor -Fuel filter -Brake rotors and pads (front and rear) Upgrades: -3rd Gen metal timing chain tensioners -3.5" intake -10% upper supercharger pulley -Bosch 011 intercooler pump |
The differential makes a lot of noise, and will need to be replaced.
Asking $3500, OBO |
Wow you're selling ?!
Originally Posted by King Charles
(Post 1995373)
