Aftermarket ECU system to control my V12 fueling
I am looking for an aftermarket ECU system and all related sensors, to control the fueling of my V12 engine. (the injectors, low impedance, original) I am still wanting to use my original distributor and single coil. 1976, 5.3, Lucas ECU. I have an aftermarket cam, and even though I had AJ6 adjust my original ECU twice, it is super rich at the bottom end and lean up top. It can't be done properly without the car... I need something adjustable to get it running correctly. A used ECU possibly? If it is all good with all the sensors and stuff.
Thanks. |
Originally Posted by virtue
(Post 2007743)
Thanks. |
I have upgraded my fuel rails to the more modern ones. I have modified my intake manifolds so, I am sticking with these. As for the injectors, the originals have been cleaned. It cost me some $, but they work like new. So changing everything back to what you recommend will not allow me to change my A/F ratio to work best with my setup. So, I still need some aftermarket ECU to adjust my fueling accordingly.
