Parting out 1996 XJR
Hello all,
I'm parting out 1996 Jaguar XJR. It was in a front end collision, but the airbags are still intact. For now the drivetrain components are not for sale until I sort out my current projects, but the rest of the car is. Let me know what you are looking for. Karolis D. |
Parting out 96 XJR
I would be interested in the Catalytic converter at $200.00. Thank you, Larry Louton 941-416-4030 e-mail nfishw@aol.com
I call dibs on the dash tweeters and the oil cooler if available. Private Message sent.
That dark stained maple should be valuable. |
I'd be interested in the washer reservoir/pump
Let me check the parts and I'll let you two know if they are good.
Originally Posted by SleekJag12
(Post 1995979)
Originally Posted by SFPat
(Post 1996048)
https://cimg8.ibsrv.net/gimg/www.jag...9a6dbe0c8a.jpg
https://cimg0.ibsrv.net/gimg/www.jag...40e83783f6.jpg SFPat, See pictures of the washer reservoir. One mounting ear is broken and there is a problem with the washer pump. The motor makes noise, but it doesn't build any pressure. Water level sensor works fine. Still interested? I can try to remove the pump from the reservoir and see if there is something blocked. |
Thank you, Karolis! The dash tweeters arrived safely (oil cooler not available now). A fair price, and a pleasure to deal with you.
Would be interested in stocking the following items as future spares:
(a) the in-cabin rear view mirror, (b) the little plastic piece that partitions the astray and the ski slope, (c) ashtray if the wood trim has no cracks (what is the condition of the rest of the wood trim?), (d) the central ventilation vent if the fins are still in good working order, (e) the speedometer if the display plate is in Km (but I know this means I would have to take the entire instrument cluster) (f) MAF (g) the timing bracket on the flywheel (factory or Andy's) (h) the Traction Control unit with the ABS module (if in good working order). (i) the leaper on the hood if it is factory original (one with a non-flat base that curves perfectly with the hood). (j) seat belts if in charcoal black or beige (not sure if a good fit as Jaguar has many variances even for X300). (k) in-cabin door handles. (l) antenna with motor if still in good working order. Has PM'ed you my email for easier contact. |
Hello, I would like to withdraw my request for the catalytic converter please.
Thank you. Larry Louton |
I'll pass on the washer reservoir
I need a complete sunroof assembly for parts. I do not need the tilt and slide mechanisms to be good.
Superchargedtr6 and Qvhk, let me take a look at the parts over the weekend and I'll let you know the status and send pictures.
If drivetrain is available, I may be interested.
lyonsfin,
Sorry, but I'm keeping the drivetrain for now, I'm still massaging the idea of putting the best of XJR into my XJC. |
I'm Interested in the following:
Tilt and slide mechanism for sun roof both sides. but especially the passenger side. really I just need the plastic piece. The throttle cable that goes from the passenger side fender to the drivers side of the engine with the plastic guide from the passenger side The interior rear view mirror if it works. if your stereo works I'm interested in it perhaps and the clock if it works. There are some plastic twist locks that hold the plastic molding down by the air cleaner and over on the passenger side by the window washer bottle... I need the square bottom pieces that mount to the metal. Also the top screw pieces as well to go with them. The cover to the passenger side tool box/spare fuse area if it's not scratched. the black /grey panel that sits on top of the spare tire if it's not cracked. Inside plastic of the glove box if it's not cracked. cup holder if it's not cracked. passenger side and driver's side door mirrors depending on condition. the hooks for the carpet by the seat (both sides) trunk button electronic key fobs drivers side door jam where it says jaguar by the floor. or pair of both depending on condition. overhead lights and garage door opener maybe. door handle cables front plastic guides and door pins that hold door panels in/on. chrome guide around body where antenna goes in and out. (the part that fastens to the body) fender tool kit if you have one. steering tilt and telescope motors and mechanisms. yellow running/signal lights from front bumper. |
If you're selling the seats, I'd be interested!
Hey Karolis, do you still have the full radio and clock assembly? (Center console) i have 96 xj12 they put after market radio in and messed everything up, i want to go back to factory. thanks J Fulton |
Yes, I do have the clock and the radio, but clock LCD is all black, the radio volume knob is missing and the volume adjustment is intermittent. Let me know if you're still interested.
Karolis D.
Originally Posted by Flex320
(Post 2027505)
intercooler
hey, do you still have the car? Any chance the intercooler wasn't damaged by the collision?
Hi, how about the wheels are they available?
