Rear anti-roll bar: XJ and XJS
I have 2 rear anti roll bars, removed from early XJS's.
There's been much discussion regarding these. I found an improvement in handling after fitting to a S1 XJ. These require a bracket on the trailing arm to mount the drop links. These can be made easily, it's a 3 sided box with hole for the bolt. Bar#1: ready to install. Bushings, drop links, and bushing mounts all good...$200US plus post. Bar #2 drop links need replacement. These may be available from S3 E Type. No metal bushing mounts. $125US plus post. Please e mail leatheriquecanada@computan.on.ca for a postal quote. It can go to the USA no problem, but it's too big for some overseas postal regulations. There's no tax or duty if going to the USA. Good luck with your Jaguars, Rob |
