Rebuilt Jaguar Engine 99-01 XJ8 XK8 4.0L V8 NNE1002PBE + $700(Core Charge) + Shipping
For Sale
Engine - Complete
Subscribe
galaxycars's Avatar galaxycars Mar 19, 2020 06:59 PM
  • Engine - Complete - Rebuilt Jaguar Engine 99-01 XJ8 XK8 4.0L V8 NNE1002PBE + $700(Core Charge) + Shipping - Used - 1999 to 2001 Jaguar XJ8 - 1999 to 2001 Jaguar XK8 - 1999 to 2001 Jaguar Vanden Plas - Los Angeles, CA 91352, United States
    Expired
    Expired
    Expired
  • Price
    $3,000
  • Location
    Los Angeles, CA, 91352, USA
  • Condition
    Used
  • Compatibility
    Model Make Year
    Jaguar XJ8 1999 - 2001
    Jaguar XK8 1999 - 2001
    Jaguar Vanden Plas 1999 - 2001
Description:
Rebuilt or Remanufactured, build again after part out for best performance. REBUILD suggests making like new without completely replacing. It is fully disassembled, has been taken apart completely and had its internal components either repaired, refinished or completely replaced with new parts.
We Replaced all the seals and gaskets, Chains, Guides, Tensioners, Piston Rings and Bearings, and everything that needs to change with either used or a new one.
We sand blasted the Head and Painted Block
Engine-Stripped.
XJ, XK. Sedan. Coupe, convertible. Without supercharger.
Engine - Stripped. Engine Complete Assembly. Fits Vanden Plas, XJ8, XK8 XJ, XK; Coupe, Convertible; w/o Supercharger. XJ, XK; Sedan; w/o Supercharger. Engine Assembly - Repair or Replace CAMSHAFT & TIMING. CRANKSHAFT & BEARINGS. CYLINDER HEAD & VALVES. MOUNTS. PISTONS. RINGS & BEARINGS. LUBRICATION. OIL PAN. OIL PUMP. VARIABLE VALVE TIMING. XK; Coupe. UPPER; XJ. All Models; Exhaust. All Models; Intake. All Models; Left; w/o Valves. All Models; Left; w/Valves. All Models; Lower. All Models; Right; w/o Valves. All Models; Right; w/Valves. All Models; Upper. Convertible; Front; Left. Convertible; Front; Right. Convertible; Grade 1; w/o Supercharger. Convertible; Grade 1; w/Supercharger. Convertible; Grade 2; w/o Supercharger. Convertible; Grade 2; w/Supercharger. Convertible; Grade 3; w/o Supercharger. Convertible; Grade 3; w/Supercharger. Convertible; Left; w/o Variable Timing. Convertible; Left; w/Variable Timing. Convertible; Rear; w/o Supercharger. Convertible; Rear; w/Supercharger. Convertible; Right; w/o Variable Timing. Convertible; Right; w/Variable Timing. Convertible; w/o Oil Cooler. Convertible; w/o Supercharger. Convertible; w/Oil Cooler.
VEHICLE FITMENT
  • 2002 Jaguar Vanden Plas | Base | 4.0L V8 - Gas
  • 2001 Jaguar Vanden Plas | Base | 4.0L V8 - Gas
  • 2000 Jaguar Vanden Plas | Base | 4.0L V8 - Gas
  • 1999 Jaguar Vanden Plas | Base | 4.0L V8 - Gas
  • 2002 Jaguar XJ8 | Base, Sport | 4.0L V8 - Gas
  • 2001 Jaguar XJ8 | Base, L | 4.0L V8 - Gas
  • 2000 Jaguar XJ8 | Base, L | 4.0L V8 - Gas
  • 1999 Jaguar XJ8 | Base, L | 4.0L V8 - Gas
  • 2002 Jaguar XK8 | Base | 4.0L V8 - Gas
  • 2001 Jaguar XK8 | Base | 4.0L V8 - Gas
  • 2000 Jaguar XK8 | Base | 4.0L V8 - Gas
  • 1999 Jaguar XK8 | Base | 4.0L V8 - Gas
  • XJ8 99 (4.0L), exc. XJR; (VIN 0, 7th digit)
  • XJ8 00 (4.0L), w/o supercharged option; (VIN C, 8th digit)
  • XJ8 01 (4.0L), w/o supercharged option; (VIN C, 8th digit), thru engine ID 0108122359
  • XK8 99 (4.0L), (VIN 0, 7th digit)
  • XK8 00 (4.0L), XK8, (VIN C, 8th digit)
  • XK8 01 (4.0L), XK8, (VIN C, 8th digit), thru engine ID 0108122359
Subscribe
Currently Active Users (1)
