Stuart S |
03-23-2019 12:27 PM |
Yes, they are Selena wheels but ...
Your Personal Profile says that you have a 2011 XF. Is it equipped with the E-diff? The OP has a 4.2L 2009 XKR Portfolio. Here's the problem:
20" Selena wheels were available to fit the XF, but I'm pretty sure that the rear offset isn't the same as on the 2009 XKR Portfolio, which doesn't have the E-diff. Also, they're not the same color. I'm also not sure if they're the same width; the XKR has staggered fitment, with 8-1/2" wide fronts and 9-1/2" wide rears.
The OP needs to make sure that the offset and width are the same as his OEM wheels. Color isn't important since you can have them refinished so they all match.
