Two 8.5x19 Polaris Wheel Sets
For SaleWheels and Tires/Axles
Description:
I have two sets of the Jaguar Polaris wheel sets from the 2004-2009 XJ. They are a 8.5x19 with a 5x108 bolt pattern with a center bore of 63.4 and have an et49.
$650 gets you a set of 4. $750 gets you a set with Pirelli tires (P6 or Scorpion) having about 5/32 of tread or better with a size of 255/40-19.
There are two extra wheels with tires, so if buying a set you can get a 5th wheel for an extra $75 without tire or $100 with the tire.
I can ship these with or without tires, but if you want them with tires, freight will be quite expensive.
Condition is probably a 7 out of 10 or a bit better with little damage to the face and only a little bit of curb rash. I can sent pictures of the individual wheels.
Both sets are in Central VA just outside Lynchburg.
Please note that all the wheels will probably need tire pressure sensors. Some just have rubber valve stems or the wrong TPMS sensors. They all hold air fine without issue, but are leaving the warning on.
