1966 Daimler V8 Rear Axel endfloat ???
Old Sep 7, 2015 | 03:58 PM
aktell's Avatar
Default 1966 Daimler V8 Rear Axel endfloat ???
Hi there,
I'm working on a 1966 rear axel assembly trying to work out how to set up the end float! I have an old W/S manual but nothing is mentioned except the tolerance of 3 to 5 Th.
I have used new bearings but what ever I do I have 30 th end float - were do I install shims as I can't find any in the parts list! Behind the bearing cap increases the float so I assume behind the bearing cone on the axel itself ???
Any help would be greatly appreciated!
rgs aktell
Old Sep 10, 2015 | 05:30 AM
John Francis's Avatar
part # 33, in attached pdf.is the shim location.
http://www.jag-lovers.org/saloons/da...e/rearaxle.pdf
Were there any shims when you disassembled it ? If you are using a locking (positraction) unit, were the spacer parts installed ? ( see # 28 in pdf. http://www.limora.com/media/catalog/.../1/1/11977.gif
Old Sep 10, 2015 | 02:55 PM
aktell's Avatar
Hi there,
Thanks for the reply! all very informative and useful yet my problem is that both bearings were damaged so I could not measure the end float before stripping and the unit did not had any shims at all. but now after reassembling with new bearings I had 30 th end float both side so I could not use any shims in the normal way and so I was after the answer what to do if you had such excessive tolerances.
Well, in the end to get to the proper end float I had to machine the outer plate (brake plate holder) to the specific set out clearance of say 3 to 5 th!
It works fine AS IS, but it can't be right that way I still think that there must be some damage to the tubs but can't find anything as the tubes look in perfect condition!
Anyway, thanks again. rgs aktell
hunterpedigo
Jun 21, 2017 08:59 PM
Typhoon
Nov 8, 2015 07:48 PM
hunterpedigo
Oct 29, 2015 05:31 PM
philwarner
Sep 5, 2015 10:05 AM
