Leaking shaft seal
Old Dec 6, 2021 | 09:04 PM
lyonsfin's Avatar
Default Leaking shaft seal
I have a minor leak where the shaft enters the rear differential in my Mk 2, 2.4. I have a new seal, bearing race & gasket, but the oil slinger is not available. Can I reuse the one in there?
Old Dec 7, 2021 | 04:16 AM
Glyn M Ruck's Avatar
Presume you mean the Propshaft/diff seal.
You can use the old slinger.
Don't touch the bearing unless you intend a complete diff rebuild crownwheel & pinion realignment & reset of the pinion preload.
Ignore the title. See this Ed China video on seal replacement & his trick to maintain pinion preload while replacing seal. Watch from 1:24
Old Dec 7, 2021 | 10:18 PM
lyonsfin's Avatar
Thanks Glyn. I was worried that if I undid the nut that the pinion assembly would loosen up. I see from the video that the If I only remove the seal, I should be OK.
BTW, my 61 Mk 2 is a South African market car assembled there. The second owner emigrated to the US in the mid 70's with his trusty Mk 2!
Old Dec 7, 2021 | 11:30 PM
Yes. Mark the pinion nut to flange. Undo nut. Remove old seal. Fit oiled new seal & gasket. Replace nut & tighten until marks line up. ~ Done
giandanielxk8
Jan 5, 2022 03:42 PM
bocagq45
Oct 29, 2014 04:41 PM
zmann96
Aug 28, 2011 06:32 PM
Kassaq
Aug 15, 2011 03:23 AM
panchostatus
Aug 14, 2011 12:48 PM
