Source for 3.8 s-type wirning Harness
Engine wiring harness. Anyone know of a good source or can i make one? |
It's not really an engine wiring harness. It is a main harness with some sections attached. Whatever, SNG Barratt can supply every single piece of harness for an S Type in correct black fabric with blue fleck, plastic sheath for under fender etc. etc. I replaced every wire on my car. Short delay sometimes required while they are made up. I would hate to try & make my own with all the required fittings etc. Bit of a nightmare.
You need to talk to them. It's not all shown on the website. |
Thanks. Is it a single wiring harness or will a set he needed? I’ll check out their site |
I bought mine from Autosparks https://www.autosparks.co.uk/finder
They are great and use all the original braiding, they probably supply Barratts! |
Originally Posted by Homersimpson
(Post 2009510)
Originally Posted by stuckon914
(Post 2009472)
Nice looking harnesses. Thanks for sharing the website. |
I replaced all the wiring in my mk2 with a painless kit. Modern style wiring, larger gauge, better connections, better insulation, 12 separate circuits marked with modern blade style fuses, easy to access relays and flasher units, etc. etc. It wasn't too hard to adapt to the car but took time and patience, perhaps not for the faint of heart. That said my lights are bright and everything works without hesitation.
I did a full re-wire myself, Lin kindly provided all the schematics in the original format so I could adapt for RHD, take a look at his website entries for this, Lin put in a huge effort compiling the website and I have to take my hat off to him for all his efforts as it is a great resource for many to follow.
MK2 Electrical System ? Valve Chatter Jag MK2 ? Valve Chatter |
