SU fuel pumps
I purchased tubs full of S type, XJ-6, and XJ-S parts.
I found what may be two brand new boxed SU fuel pumps which I want to install in my S type. The date in the Instructions Sheet is 2009. does anybody know to who I can send them in the USA to get them tested before installing them? Thanks. |
I am sure Primaz has recommended someone for SU stuff before, maybe send him a PM
Why not just test them yourself ?
Vintage Jags could probably do that. They rebuild them.
Originally Posted by JeffR1
(Post 1843919)
Originally Posted by Jose
(Post 1845828)
I don't know how!! I mean, without connecting fuel lines and all that stuff, which I want to avoid, testing them with 12volts no problem, but if you've ever removed and reinstalled a fuel pump in the S type, you would understand why.
I tested them, one almost flew out of the bench when I applied 12 volts.
the second one is dead, well no ticking. |
Open the cap and have a look at the points, they are probably burnt, easy to replace from Burlens and there are write ups regarding how to ‘set’ them once you have replaced.
thanks, I will check that. You mean the black plastic cap, correct?
Thank you TilleyJon. great article.
