1990 XJs V12
I Have A 1990 Jag XJS
V12 Right Bank Cat Converter Glowing While Idling Recently Cused Fire Have Damage Repaired Looking For Cause Any Help Appreciated Thanks Al |
Almost certainly a typical failure of the Marelli ignition system...which is really two ignition systems in one, leaving one side or the other prone to failure while the opposite side still functions. Most commonly it's the RH side that fails.
First, remove the distributor cap to inspect the rotor. You may well find the problem right there. There are other possible faults, though, so post back. Cheers DD |
Welcome to the forum Al,
Good to have you with us at Jaguar forums. Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Northeast Region forum by following this link https://www.jaguarforums.com/forum/us-northeast-35/ to find other members in your region. Enjoy the forums. Graham |
1990 Jag V12 Glowing Cat
Doug Thanks For Rapid Response
We Will Check on That Thanks AL |
Welcome
Welcome aboard Al
Hello, Al,
I'm sorry to read of your V12 fire. Not the first one I've known of either. One of my Jaguar club fellow members, had the same experience as you; after repair named his car Phoenix. 2 months later it flamed again but that time, completely beyond repair and it went to a junk yard in Rancho Cordova. I sincerely hope yours does Not meet the same fate, and you get that ignition fixed properly. Welcome to the forums from ElinorB. (';') |
Welcome to the forum. I feel your pain, there is a good reason my car is called "Fireball":icon_goofygrin:
Welcome.
Yep, Doug has nailed it. Marelli fire is common, and well documented in the XJS Tech Section, that Graham has linked you to, including ALL the fixes. |
Welcome to Jaguar Forums Al,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
