2004 xtype 2.5awd error code p1647 heated oxygen sensor control module bank 1 open /
Hi all. Hoping you can help.
I have a 2004 xtype 2.5awd throwing error code p1646 heated oxygen sensor control module bank 1 open / shorted had a guy replace 2 sensors already but they appear to be the easy to get to ones on each bank. Is this code indicating I now need to change the one at the back of the engine against the firewall and have to remove the manifold and do a contortionist act to get the swine out or is it indicating a dodgy relay or a module somewhere needs changing. any help is appreciated as I'm on the verge of having to cut my losses and scrap the car which I really dont want to. Thanks. |
Welcome to the forums Xtype v6 awd. Xj8 4.0 1998,
Scrap it! Lie down in a darkened room until the madness passes. Many have battled P1647 and won. Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/u...r-atlantic-66/ to find other members in your region. Please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started. Enjoy the forums. Graham |
Welcome aboard.
Welcome to the Forums.
Darkened rooms are my therapy also, been so for many years, and too many Jags. Good luck. |
Welcome to the forums.
Welcome to Jaguar Forums Xj8 4.0 1998,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Hello,
Don't despair quite yet. Many of us have been where you are, Consumed by frustration, anger and disappointment and Rage, to the point we want to stuff rags in the gas tank, light it off! ans walk away. But then someone on one of these forums gives an answer, a solution or a trick we didn't know, and although sometimes it's not an easy thing, at least we Know the problem CAN be addressed and there's hope after all. Welcome to the forums from ElinorB. (';') |
