2008 X-type 3.0 Error Codes P0352 P0354 P0356, & P1368
Hi everybody. I'm a new member. First time posting but i've frequent this forum. Up until recently, my car has been flawless. Now I'm getting multiple error codes. up to 12 codes at a time but P0352 P0354 P0356, & P1368 are consistent. I understand them to mean bank 2 (left) is having misfires. I've checked for vacuum leaks. change upper & lower intake manifold gasket, IMT gaskets, and chased down the wiring all the way back to the ECM and didn't find bad wires. P1368 says a Ignition amplifier, bank 2 could be a problem. Does this car have an ignition amplifier or does the single come from the ECM?
An interesting fact is when i clear the codes at a high rev, the engine runs fine until i let off of the accelerator and then re-accelerate. then it goes back to running poorly. which leads to me it'as not a vacuum leak. Any help is appreciated. |
Welcome to the forum dbourg, Good to have you with us at Jaguar forums. A re-post in X-Type forum will get this to the attention of members with the same model. Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Southern Midwest Region forum by following this link https://www.jaguarforums.com/forum/u...rn-midwest-67/ to find other members in your region. Enjoy the forums. Graham |
Welcome to the forums.
Hello,
I know how frustrating it is to have error codes for no apparent reason. However, I'm sure you'll have them all sorted out with the help you find here. Welcome to the forums from ElinorB. (';') |
Welcome to the Forums.
Welcome aboard. |
Welcome to Jaguar Forums dbourg,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
I still have not found the problem. Can any of you tell me the significance on the ECM number? I found many that should fit by application but the part number varies a bit. I need JAG# 8X43-10K975-AA (DENSO MB079700-9670). Will any fit by application and will they work without reprogramming?
The ECM is both Market and VIN range specific. In addition, it is a programmable module and will not "plug & play".
Graham |
