Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   New Member Area - Intro a MUST (https://www.jaguarforums.com/forum/new-member-area-intro-must-5/)
-   -   ac compressor removal instructions 1988 sjcs (https://www.jaguarforums.com/forum/new-member-area-intro-must-5/ac-compressor-removal-instructions-1988-sjcs-56035/)
jjborst1 06-09-2011 01:18 PM
I was wondering if anyone can tell me the steps for removing a ac compressor I am not a mechanic but will not pay the price they want .If not any good manual out there for this task.
Fraser Mitchell 06-09-2011 04:44 PM
First thing to do is not to attempt removal without extracting the refrigerant gas into a closed tank, i.e. do not vent it to atmosphere, it is illegal and dangerous. Air con specialists are the ones who have the kit to do this, and I am not sure why you want to do it yourself if you are not a mechanic. Air con maintenance and repair is is one job to leave to the experts.
Is there no air-con shop near you with a better price ? I suspect you have been quoted for a new compressor. They are not cheap items, but you can find cheaper on the internet, if you can get an air con shop to swap them out for you.
Nevette 06-09-2011 04:55 PM
Welcome to the forum and best of luck with your compressor. When you can, tell us more about your Jag.and maybe post a picture or two. Have a good time here.
jjborst1 06-09-2011 05:11 PM
It has no refridgernt in system It doesnot look complicated and I can get a compressor for a third of the price I was quoted.I just want to make sure I do it right.
Norri 06-09-2011 07:35 PM
A warm welcome to you JJ.
This is the welcome section, please do not start multiple posts asking the same question.
If you need technical advice the relavant section for your vehicle will yeild the best results.
Gus 06-10-2011 07:19 AM
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
This section is for an intro if you have a question go to the section for your car. We have a lot of talented people to help.
Doug 06-10-2011 08:24 AM
It'll be pretty easy since there's no freon in the system to deal with.
Two bolts hold the compressor in at the fron and two hold it in at the rear. Remove bolts, wires, and bolts...and lift it out.
You'll have to remove the cruise control bellows to reach the rear bolts.
jjborst1 06-10-2011 03:45 PM
Thanks It didnt look complicated
motorcarman 06-10-2011 04:02 PM
The Harrison A6 compressor is the same one used by GM cars since the 60s??
Make sure you get the compressor with METRIC threads and not the standard ones.
You can use the standard one but you will have to swap out all the mounting hardware to avoid ruining the threads.
Good luck with the swap.
bob gauff
jjborst1 06-10-2011 04:20 PM
Thanks for the info ..............JJ
