Change direction of dipped H/lights
Is it possible for someone to change the direction of the headlights on my 07 x type door driving on the continent?
Welcome to the forums Aieloman, Some Jaguars (e.g. 2007 XK/XKR) have a lever on the back of the headlamp to switch the dip from left to right and later ones like mine have headlamps which don't require adjustment for LHD or RHD. The dip beam direction on yours is a function of the pattern on the headlamp glass. Options are either swap for LHD (expensive) or use stick on "beam benders". Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region. Enjoy the forums. Graham |
Welcome aboard.
Welcome to the Forums.
Welcome to the forums.
Welcome to Jaguar Forums Aieloman,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Hello,
Welcome to the forums from ElinorB. (';') |
